Cisco Unified Wireless IP Phone CP-7920
The Cisco Unified Wireless IP Phone 7920 provides is the wireless IP phone for the Cisco Unified Communications family of products. The phone supports a host of calling features and voice-quality enhancements. Because the phone is designed to grow with system capabilities, features will keep pace with new system enhancements.
Features:
- Wireless Access Protocol: IEEE 802.11b, Direct Sequence with Dynamic Rate Scaling at 1, 2, 5.5, 11 Mbps.
- Frequency range: 2.4-2.497 GHz
- Wireless output power: 100mW Effective Isotropic Radiated Power (EIRP) with scaling at 1, 5, 20, 50, 100mW
- Range: 500-1000 ft / 15-300m indoors depending on environment
- Access point support: Cisco Aironet series access points including the 1200, 1100, 350 and 340 series
Compatible with:
- Compatible with Cisco Unified Communications Manager Versions 5.0, 4.2, 4.1, 4.0, 3.3, and later, and Cisco Unified Communications Manager Express Versions 3.3 and 3.2, using the Skinny Client Control Protocol (SCCP) Compatible with Cisco Unified Survivable Remote Site Telephony (SRST) Version 2.0 and later
- Cisco Compatible Extensions Version 2.0
mehr Infos finde Ihr hier.
Die Telefone sind Neu und mit Originaler Verpackung, sie wurden nur zum Fotografieren & einen kurzen Test ausgepackt.
Pro Stück 65.00
Abholung erwünscht in : Dietikon, Zug, Bremgarten
