Compaq IPAQ 3110
  • Weiss zufällig jemand wieviel so ein Teil noch wert ist ?
    Daten:
    Dimensions (HxWxD)
    5.11 x 3.28 x 6.2 inches
    Weight
    5.77 ounces (including battery)
    163.5 g (including battery)
    Processor
    32-bit Intel StrongARM SA-1110 microprocessor running at 206 MHz on a 100 MHz memory bus
    Display
    Semi-transmissive graphic supertwist nematic (STN) liquid crystal display (LCD)
    Resolution: 240 x 320
    Colors: 15 shades greyscale
    Dot Pitch: .24 mm
    Viewable image size:
    2.35 x 3.1 inches (3.8 inches diagonal)
    59.6 mm x 78.8 mm (96.5 mm diagonal)
    Storage / Memory
    16 MB Ram / 16 MB Rom
    Audio
    Audio record and playback (play MP3 music or audio programs from the Web)
    One-touch instant-record button (for voice memos)
    Integrated speaker, stereo headphone jack
    Integrated microphone
    I/O Communications
    USB: The iPAQ H3100 Series ships with a USB (UHCI) cradle. This cradle connects to a computer via a Universal Serial Bus (USB) connection. A USB cable is also provided to directly connect the device to a USB port on a PC
    Infrared: The module supports slow Infrared (SIR), also defined as IrDA 1.0 with a maximum transmission rate of 1.15Mbps
    Serial A serial cable is available. This cable connects to the USB port on the iPAQ H3100 Series and wires to a serial COM port on the PC
    Operating System/Software
    Microsoft Windows CE 3.0 for Pocket PC
    Active Sync 3.1 Desktop Synchronization
    Pocket Outlook (Calendar, Contacts, Tasks, Notes, Web Browser)
    Office Apps (Pocket Word, Pocket Excel, Microsoft Reader)
    Voice Recorder
    File Explorer
    Handwriting Recognition
    Power
    950 mAh Lithium Polymer Estimated life: 14 hours
    Recharging: full charge takes approximately 3+ hours
    Input Devices
    Stylus
    Software based keyboard
    Connectors
    Infrared (IrDA 1.2) port
    Communications port for serial, USB (UHCI), and cradle docking connections
    100-pin universal connector for Compaq Expansion Pack System
    Stereo headset jack supporting an earpiece/microphone headset
    DC jack power connector
    External Storage
    CF Card Expansion Jacket adds a CF Card Expansion Slot to the iPAQ Pocket PC
    Operating Temperature
    32° to 104° F
    0° to 40° C
    Operating Humidity
    20% to 90%
    Regulatory Marks
    Electrical: FCC Class B, VCCI, CE, C-Tick
    Safety: CE Marking, C-UL, NOM
    Miscellaneous Features
    Four Customizable Application Buttons and One Touch Instant Record Button
    Headphone Jack Integrated
    Front Mounted Microphone and Speaker
    Joystick Controls (Four directional buttons and one center action button)
    Und noch ein Pic
    Was schätz ihr hat es noch wert ganz genau ist es : Compaq iPaQ 3110 inkl. Ladestation seriell, Netzteil, Hülle, Outlook 2000, Word, Excel
  • hmm.. wohl nicht mehr viel.. ich hab meinen vor ca. 7mt inkl. dem cf-jacket ner 128mbyte karte für 200.- auf ricardo verkauft...
    Workstation: AMD Ryzen 7 3700x, 16384Mbyte DDR4, GeForce RTX 2080, 1x500GB WD Black SSD M.2, 1x4000GB WD SATA, Windows 10
  • Kommt ganz drauf an wie guet die Akkus noch sind, wenn die noch lange halten kommen die 50.- schon etwa hin.
    Aber viel mehr sind die auf Grund des S/W-Displays nicht mehr wert..
