Hallo zusammen,
das Laptop möchte ich verkaufen. Nur hat das Cover auf der Front einen Kratzer und einen Schaden (siehe Pix).
Infos beim STEG mit einem Neupreis von Sfr 1549.-
Ich stelle mir so Sfr 500.- vor -> was meint Ihr, ist das realistisch?
Konfiguration:
Lenovo V200 (0764-32G) Intel® CoreTM 2 Duo Processor T7300, 2.00Ghz (TF132ZA)
Kurze Beschreibung: 4GB Memory/120GB HD/12.1" Screen/Webcam/Bluetooth/zwei Akkus (Akku A, Laufzeit c.a. 20min/Akku B Laufzeit c.a. 90-110min)/LeaderCase
Alter: 14 Monate
Architecture
Bus type/architecture: PCI/PCI Express
Bays: No
Indicator light: Yes
Form Factor: Notebook
Display
External display supported: Yes
Simultaneous external display: Yes
Screen type description: WXGA VibrantView TFT with integrated camera
Viewable image size (diagonal): 12.1inches
Screen illumination: Backlit
Max colors or grey shades: 16777216
Max resolution: 1280x800
Graphics Subsystem
Video RAM std/max: -- / --
Graphics chipset: Intel Graphics Media Accelerator X3100
Graphics type: --
Video RAM type: DVMT
Max resolution (with max video RAM): 2048x1536 16777216 colors
Max colors (with max video RAM): 16777216
Graphics bus interface: PCI Express
ReturnBack to top
Processor
BIOS type: Flash ROM
Processor manufacturer: Intel
Processor (CPU): Intel® Core 2 Duo T7300
Processor internal clock speed2: 2.00GHz
Front Side Bus: 800MHz
Memory
Memory (RAM) std/max: 2x2048MB / 4GB
RAM slots total: 2 SODIMM
RAM slots available: 0 SODIMM
RAM speed supported: 667MHz
RAM type: PC2-5300 DDR2 SDRAM
Hard Disk
Hard disk size1: 120GB
Hard disk type: Serial ATA
Optical device
Floppy diskette size: --
Optical device: DVD Recordable (Dual Layer)
Optical device speed8: 24X Max
Device interface: PATA
Audio
Integrated speakers: 2
Speaker power rating: 2 Watts
Volume control buttons: Yes
Speaker Quantity: 2 (Internal Speakers)
Audio chipset: Intel High Definition Audio
Audio data width: 24-bit
Communications
Fax/modem: 56K V.92 designed modem
Fax/modem speeds: 56Kbps data/14.4Kbps fax
Infrared port:
Infrared port speed: --
Wireless standard: Intel 4965AGN
Network card: 10/100 Ethernet
Network interface: Ethernet-Integrated
Accessories
A/C adapter:
Worldwide A/C compatibility: Yes
Port replicator: None
Standard Features
Pointing device type: Industry Standard Touchpad
Keyboard type: Full size
Keyboard light:
Power Management 5
Heat emissions: 65W
Sound emissions: 37dB
Battery life - min/max: 1.8 Hrs
Battery type(s): 3 Cell Lithium-Ion
Charge time - on/off: 2.6Hrs / 2.7Hrs
Expansion Options
Plug and play support: Yes
Slots total (free) and type:
Parallel port type:
Ports: External Display (VGA)
External Microphone/Line-In
Headphone / Line out
IEEE 1394
RJ-11
RJ-45
3 USB 2.0
5-1 digital media reader (SD/MMC/MS/MS pro/XD)
Weight & Dimensions 6
Weight: 1.82Kg
Height: 31.7mm
Width: 305mm
Depth: 227mm
Travel weight: 2.19Kgs
Security
Security features: Hard disk drive password
Power on password
