nForce2 und Linux
NVIDIA a mis en ligne la version 1.0-0248 de ces drivers nForce pour Linux. Voici la liste des nouveautés, dont la plus importante est bien entendu le support du nForce2 :
- Added PCI ID support for nForce2 MCP2-T and MCP2-A to the i810_audio driver.
- Cleanup of spec file and Makefiles
- SRPMs and tar files now use local system's i810_audio.c file, and complain if not there (this makes them more distribution independent)
- Changed code to compile properly with gcc3.X and gcc2.X
- Added support for Mandrake9.0 and Redhat8.0
- nForce2 support for network driver
