Powerline Ethernet Switch Zyxel PLA470 v2
  • Hätte zwei Zyxel PLA470 v2 abzugeben. Sind noch Praktisch da beide einen 4Port Switch integriert haben.
    Preisvorstellung Bar 60.- für beide.
    System Specifications
    • HomePlug AV 200 Mbps
    compliance Data Rate
    • Power Line Network:
    Supports up to 16 Powerline- devices
    communicating on a single network. Each
    Powerline Ethernet adapter supports 15
    remote Ethernet addresses. With total 4
    groups then it can support up to total 64.
    • Modulation:
    OFDM Symbol Modulation, supports QAM
    1024/256/64/16, DQPSK, DBPSK and ROBO
    Carrier modulation schemes
    • Frequency Band: 1.7 MHz ~ 30 MHz
    • Coverage Area: up to 300 meters
    • Security: 128 bit AES encryption
    Hardware Specifications
    • Interface: 4-port 10/100 Mbps Ethernet, RJ-45, with
    automatic MDI/MDIX
    • Power Input: 100-240 VAC, 50/60 Hz, 0.2 A (Max)
    • LED Display:
    - Status LED Power
    - Powerline Link and Activity
    - Ethernet Link and Activity
    - Throughput Indication
