MRTG: Extrem falsche Werte nur in den Diagrammen
  • Hallo,
    Ich habe MRTG-2.17.4 auf WINDOWS-7 und einige INC-Files von CrazyCat.
    Eines von diesen ist (als Beispiel):
    # File: dvbdataex-level.inc
    # DVBDataEx receiver signal level
    Target[dvbdataex-level]: `signalex.exe level`
    MaxBytes[dvbdataex-level]: 100
    Title[dvbdataex-level]: DVBDataEx Signal Strength
    Options[dvbdataex-level]: integer, gauge, nopercent, growright, unknaszero, noo
    ShortLegend[dvbdataex-level]: %
    YLegend[dvbdataex-level]: Strength %
    LegendI[dvbdataex-level]: Strength:
    Legend1[dvbdataex-level]: Strength (percent)
    PageTop[dvbdataex-level]: <H1>DVBDataEx - Signal Strength (Kharkov)</H1>
    Dies ist mrtg.cfg:
    # Created by
    # cfgmaker public@192.168.238.238
    # --global "WorkDir:
    # C:\Tools\Apache_Software_Foundation\Apache2.2\htdocs\mrtgdata"
    # --output mrtg.cfg
    # von DG1GWY neu eingerichtet am 21.06.2015
    ### Global Config Options
    WorkDir: C:\Tools\Apache_Software_Foundation\Apache2.2\htdocs\mrtgdata
    RunAsDaemon: yes
    Interval: 5
    # These are default values:
    XSize[_]: 500
    YSize[_]: 300
    Timezone[_]: UTC
    TimeStrPos[_]: GE
    TimeStrFmt[_]: %Y-%b-%d
    ### Global Defaults
    # to get bits instead of bytes and graphs growing to the right
    # Options[_]: growright, bits
    BodyTag[_]: <BODY LEFTMARGIN="1" TOPMARGIN="1" BACKGROUND="paper.jpg">
    EnableIPv6: no
    options[_]: growright
    # System: receiver
    # Description: Hardware: Intel64 Family 6 Model 58 Stepping 9
    # AT/AT COMPATIBLE - Software: Windows Version 6.1
    # (Build 7601 Multiprocessor Free)
    # Contact:
    # Location:
    # von David Taylor:
    Include: tellicast-receiver.inc
    # and files for monitoring DVBDataEx:
    #Include: dvbdataex-lock.inc
    Include: dvbdataex-level.inc
    Include: dvbdataex-quality.inc
    Include: dvbdataex-rflevel.inc
    Include: dvbdataex-snr.inc
    Include: dvbdataex-ber.inc
    SignalEx.exe ist das Hauptfile für alle dvbdataex-*.inc
    Wenn man nun z.B. SignalEx.exe level, SignalEx.exe quality, ... aufruft, werden die Werte
    korrekt angegeben. Aber in den Diagrammen werden extrem falsche Werte angezeigt:
    level: anstatt 62% wird angezeigt 2%
    quality: anstatt 43% wird angezeigt 2%
    snr: anstatt 11,6 wird angezeigt 0,2 dB
    Merkwürdigerweise sind alle diese Werte zeitunabhängig konstant.
    Außerdem wird im Kopfteil dieser Diagramme angegeben:
    "The statistics were last updated Saturday, 27. June 2015 at 16:47 UTC.
    at which time ´unknown´ had been up for unknown."
    Das bezieht sich alles nur auf die genannten dvbdataex-Files. Alle
    anderen geben richtige Werte fehlerfrei wieder.
    Wer kann mir hier helfen? Wer sieht die Problemecke?
    Werner.
  • Zum debuggen:
    - im .inc file signalex.exe mit vollem Pfad aufrufen
    - die rrd db mal exportieren in XML und schauen was fuer Werte drin stehen.
    lg
    hitch
    Media: Synology 2x2TB , Popcorn v8, Sonos ZP120, ZP90, 2 Play5, 4 Play1
    Laptop: Thinkpad X220 - I7 , IPS, 16GB DDR3, 256GB SSD + PE4H + GTX580
    Coffee: DC Mini / 2x Vario v2 / Gene CBR-101
