[v:] Toshiba Port Replikator [s:]512 MB DDR333 SoDimm
  • verkaufe:
    1x Toshiba Advanced Port Replicator 3
    ist brandneu und OVP der einzige Mangel: Das Netzteil dazu fehlt. Es passt aber das normale Toshiba NT.
    Dafür billig für 70.- plus Versand statt 230.-
    Part Number:
    PA3314E-1PRP
    Parallel port
    1 port (pass thru)
    Serial port
    1 port (pass thru)
    External monitor port
    1 port RGB, 1 port DVI (can not be used simultaneously)
    USB port
    4 ports (USB2.0) - If USB 2.0 is not integrated in the notebook they will operate at USB 1.1 speeds
    PS/2 keyboard port
    1 port (pass thru)
    PS/2 mouse port
    1 port (pass thru)
    Line in
    1 port
    Line out
    1 port
    Built-in Ethernet connection
    1 port (pass thru, RJ45), up to 1Gigabit Ethernet where supported on the notebook
    Other drive bay
    1 IEEE 1394 (Firewire) port
    Kensington cable lock slot
    Yes
    Dimensions
    (W x D x H) 356 x 160 x 54mm
    Weight
    1.23kg
    Docking Status LED
    Yes
    Compatability Slide positions 1 - 4.
    Position 1: Portégé 40xx, M100 series.
    Position 2: Tecra 9xxx, M1, S1, Sat Pro 6xxx, M10 Series.
    Position 3: Portégé M200 Series.
    Position 4: Tecra M2 & future dockable notebooks
    Ich suche dafür 512MB DDR Ram SoDimm 5333 CL2,5
    2 Mal editiert, zuletzt von 2cool4u ()
