Exchange 2003
  • Hi all
    Ich denke weniger, dass jemand schon viel Erfahrung damit hat, aber vielleicht habe ich ja Glück!
    Wie aktiviere ich die "IFS-Schnittstelle" unter Exchange 2003?
    Thanks
    Idoneus
  • Du meinst, dass M: Drive Theater wieder aktivieren?
  • Note Do not enable the drive M mapping unless you have a specific reason to do so.
    Kursleiter hats auch nicht empfohlen..
    To Enable the Drive M Mapping to IFS in Exchange Server 2003
    WARNING: If you use Registry Editor incorrectly, you may cause serious problems that may require you to reinstall your operating system. Microsoft cannot guarantee that you can solve problems that result from using Registry Editor incorrectly. Use Registry Editor at your own risk. To enable drive M in Exchange Server 2003:
    Click Start, and then click Run.
    In the Open box, type regedit, and then click OK.
    Locate and then click the following registry key:
    HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\EXIFS\Parameters
    On the Edit menu, point to New, and then click String Value.
    Type DriveLetter, and then press ENTER.
    On the Edit menu, click Modify.
    In the Value data box, type M, and then click OK.
    Note If you want to map IFS to a drive letter other than M, type the drive letter that you want in the Value data box.
    Quit Registry Editor.
    Restart the Exchange Information Store service.
    Drive M is not visible until you restart the Exchange Information Store service.
    http://support.microsoft.com/d…s;821836&Product=exch2003
  • Ich frage mich nur, was der Vorteil davon ist, wenn man die Dingens einschaltet. Microsofts Sale-Argument ist ja gerade, dass es KEINEN M: Drive mehr benötigt (gut, beklopptes Argument, aber trotzdem...).
