geiles Board! allerdings halt ziemlich teuer
http://firingsquad.gamers.com/hardware/it7max2/default.asp
interessanter Hinweis im Artikel:
''Overclocking: Like all of ABIT's motherboards, the IT7-MAX2 is a champ in the overclocking department. Bus options from 100MHz-250MHz are available in 1MHz increments, and for added overclocking success, the speed of the PCI bus can be locked. Some may complain that the 1.7V limitation hurts the IT7-MAX2, but for extended use with today's 0.13-micron Northwood Pentium 4 processors, we understand why ABIT decided to keep the voltage down. Electromigration is one menace that isn't discussed as much as it has been in the past, but it's still very much a clear and present danger when it comes to system durability. We've seen many horror stories of 1.6GHz Northwood owners who were a bit too aggressive in the voltage department when overclocking. Things worked fine at first, but today many of those CPUs are now dead .''
Vielleicht sollten wir auch mit den P4 etwas vorsichtiger umgehen ![]()
